why is it not Connect ?
(2,416 Views)
Hey,
what datatypes are in your cluster?
The Cluster to array function converts a cluster of elements of the same data type to a 1D array of elements of the same data type.
CMW
(2,409 Views)
If your cluster is all booleans, then it should work just fine.  What exactly are you trying to do here?
GCentral
(2,369 Views)
maybe is better to post a pic of front panel of the cluster to let us know what type of data types are you using in your cluster.
Regards
(2,339 Views)
your cluster most likely contains data types other than boolean
(2,331 Views)
