04-11-2011 10:13 AM
I have just installed an evaluation version of LabView 2010. But, I notice that when I create a LV program and descend down a subVI (this is subVI is also created by me, not a reference to a library), it only opens a read only version of the subVI of which I descend to. The window title also shows the subVI descended is a clone version, not editable. Why? Is it because of it is an evaluation version?
Solved! Go to Solution.
04-11-2011 10:41 AM
The VI is Reentrant. Since many can use the VI at once it opens in read only mode and you only look at a specific clone of it.
/Y
04-11-2011 11:05 AM
But, I only have one VI opened. It is still opening up a read only version when I descend down to a SubVI from that the top VI that is the only one opened in Labview. How do you explain that?
04-11-2011 11:17 AM - edited 04-11-2011 11:25 AM
If you are using a Project, try opening the sub-vi through the project, and not through the calling vi.
If not using a project, open it the traditional way: File>Open> browse to the sub-vi and select it.
Alternatively (and more simple) try ctrl-M on the opened clone to make it the master.
To check if it is re-entrant, in the File menu, select VI Properties> Execution
Look if there is a checkmark in the Re-entrant execution box.
It does not matter if you only have one re-entrant vi opened. If you opened if from the calling vi, it will be a clone. Annoying, yes.
04-11-2011 12:50 PM
Thanks, that is crystal clear.
04-11-2011 01:58 PM
Glad to help
