12-31-2014 12:00 AM
Hello
I made a program that work correctly. i want use it in another computer, without install labview program. result, I used an installer, but when I make an installer, it dosn't work at all. actually, after run my exe file of installer, I cant find anything in computer to click on and see the program. Can you help me?
I attach my process to make an installer.
Best Regads
12-31-2014 12:12 AM
Start by making an executable. Use that as your source code.
12-31-2014 12:21 AM
Thank you natasftw
may you explain more? do you mean I use application (exe) like attached picture, and I add it, to files of installer that I make them in previous step?
Best Regards
12-31-2014 03:25 AM
Yes, first you need to build an application, then an installer for the application.
