which usb module or DAQ Card should i use for vibration testing
hello everyone,
                    I'm Labview 7.1 user.. i have project where i need to measure vibrations... the vibrations are from road roller... and this is the 1st time i'm dealing with vibrations so can anyone plz suggest me which USB module or DAQ card should i use.
(2,129 Views)
Hi RupaliG,
                 See this:-
                 http://www.ni.com/white-paper/2955/en
Thanks as kudos only:)
(2,126 Views)
hello Danil33
                  Can I use USB 6008 for vibration testing... It's not there in list of wht i read in ur link..
(2,112 Views)
USB 6008 is a Multifunction DAQ card.You can use this if you want to Measure/Generate Analog(Voltage) & Discrete signals in your measurement system.
It all depends on what you want to measure .
For USB based Vibration measurement devices look here.
(2,110 Views)
