09-21-2006 07:02 AM
09-21-2006 07:26 AM
09-21-2006 07:29 AM
09-21-2006 08:26 AM
You may get many differing opinions on this one..
It's probably related to what good / bad experiences people have had in the past with the OS.
My prefered OS has always been Win-2000. Maybe since I had no trouble working with it & Labview.
XP? Hum... do a search on Win-XP and do a bit of reading. However, I must say that since SP2 and recent updates, it has improved.. and is Okay..
And yes... way too many processes running in the background. I've been removing them.. one by one 😉
09-21-2006 09:22 AM
If you want guranteed timing, you have to use a Real-Time system with RT programming techniques. We do have control systems running on XP for months at a time without crashing and without being too slow (mind you, their normal response frequency is only a few Hz). The key is to make the computer a dedicated one. If people don't install junk on XP, then it's stable and runs perfectly well for as long as you want it to. If you disconnect it from the network, get rid of the virus scanner, get rid of the automatic updates and remove unnecessary services (that one might not be necessary) it will probably react fast enough for most stuff you would try to throw at it, especially if you set your process to have high priority.
All this, of course, is only relevant if your program doesn't require high performance (speed, memory, etc.). If it does, then you would have to do some special things no matter which OS you're using.
09-21-2006 11:57 AM
