06-13-2012 01:45 AM
Hi all.
What tools should i change/add so that when i type { eg. 123451R in the ( student admission number text box) } it will only appear other information,such as his name and grade???
Or do i need to make another subVI ??
Sorry for asking so many questions these 2 days :l
Thank in advance 😄
06-13-2012 02:01 AM - edited 06-13-2012 02:01 AM
I can't open your VI as Iam using LV2009.
Anyway,from reading your post I have a suggestion use a string array(control or indicator as per your requirement).Then it is possible to enter 123451R.
06-13-2012 02:10 AM
I don't really understand your question. What exactly are you trying to do? Are you trying to query the DB for the information based on this student ID?
06-13-2012 02:16 AM
i am using LV2011.
okay i wil try out ur method.
Thanks.
06-13-2012 02:20 AM
Yup i am using DB.
06-13-2012 03:43 AM
Btw the way is it use a string array(control or indicator) at the DB tools select data.vi ???
On the point/pin called "condition" ??
06-13-2012 03:47 AM - edited 06-13-2012 03:48 AM
Can you attach a screen shot of your Block diagram?
06-13-2012 04:01 AM
06-13-2012 04:19 AM
By doing so,what you are trying to achieve?
06-13-2012 04:24 AM
when i type something , eg 123451R, at the "student admission number" ( the textbox) .
I wan to get this student details, such as his name and his grade on the table.
