11-18-2013 11:24 AM
Hi all,
I have a question about the behavior of the analog output on a single AO channel. If I write a single voltage (1.2volt) to an AO channel and keep the operation lasting for 3ms (using delay). I wonder after 3ms, what state will that AO channel be? Will it maintain the same voltage or will be reset (to zero) or whatever?
11-18-2013 11:39 AM
An Analog Output will hold the last value until the device is reset or a new value is written. It is advisable to set the AO channels to 0 when you are done with them.
11-18-2013 11:39 AM
It will remain at the last output value until the device is reset or something else needs the AO resources
11-18-2013 11:50 AM - edited 11-18-2013 11:54 AM
just to piggy back off of what was said....
