webservice - upload .net stream
Hi
I imported several webservice vi, according to webservice document, there is one service, which has a parameter is stream bytes. customer demonstrated the way of using C# to read/convert a file to bytes stream.
byte[] FileToStream(string fileName)
        // Open file
using (FileStreamfileStream = new FileStream(filePath, FileMode.Open, FileAccess.Read, FileShare.Read))
            // read file byte[]
byte[] bytes = new byte[fileStream.Length];
fileStream.Read(bytes, 0, bytes.Length);
fileStream.Close();
            // convert byte[] to Stream
            Stream stream = new MemoryStream(bytes);
byte[] bytes = new byte[stream.Length];
stream.Read(bytes, 0, bytes.Length);
        // set position
stream.Seek(0, SeekOrigin.Begin);
return bytes;
My question is how can convert a file (in fact it is a pdf file) to that kind of byte stream which is expected by that webservice?
thanks
WD
Message 1 of 1
(2,491 Views)
