webservice CVT example
       I have downloaded the CVT example. when i run the webserver and run example run in the CVT example i get Access error on the webpage. Any ideas?
(2,613 Views)
the access function returns an error if you try to access a variable that is not defined in the CVT.
Did you defined your variables?
Additionally the initialization is defined using a cluster array that contains the attributes of all variables or can be loaded by file.
You can get more information under following link (caption API-Using the CVT)
http://www.ni.com/example/30326/en/#toc4
(2,569 Views)
