wanted to build a vi to simulate press and hold button on a panel.
on some industrial panels (press machine) there is a button which should be pressed and hold to activate all the other buttons for saftey reasons for example. wanted to simulate this by forcing user of the application to press and hold a key from keyboard while clicking over the rest of buttons on the front panel of the application (by mouse). Obvisouly, all the button on the fron panel of the application should work (by mouse click) unless the press and hold button, which get command from key board, is activated.
At the end the status of the press and hold button should change to false after each time one of the other buttons are pressed!
thanks for follow up.
Message 11 of 16
(1,288 Views)
David,
Thats exactly what the vi i sent you does, all you have to add is a reset button to the vi and it will do all you are after.
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
Message 12 of 16
(1,287 Views)
Accepted by topic author David1980
David,
This should do what you are after. It now has a reset. Use the example to construct what you actually need.
Rgs,
Lucither
Message 13 of 16
(1,282 Views)
Lucither!
Thx Smiley Wink, trying your VIs now !
the other reply was to Steve and PCSNF who wanted more elaborations.
David
Message 14 of 16
(1,271 Views)
I think this may be close to what you want.
LabVIEW 2012
Message 15 of 16
(1,242 Views)
How to simulate mouse click and hold the release?
Message 16 of 16
(984 Views)
