02-11-2011 11:15 AM
I'm sure this is a total noob question, but here it goes.
I have a test device that spits out data on a serial line after every test (about 1 or 2 minutes). This device is not close to my pc so it has a serial to ethernet converter connected to it. All is well with the data getting to my pc but I dont know when the test is completed.
My only solution is to stay connected while having TCP Read.vi in a loop and ignoring the timeout error (56). I don't want the timeout input to be set to infinity because if, for some reason, the test never completes, my program is stuck.
Any ideas? Your input is greatly appreciated.
02-11-2011 11:42 AM
I'm not clear what you're asking here. Why not just set the timeout value to slightly more than 2 minutes? Otherwise, there's nothing wrong with putting the TCP Read in a loop.
02-11-2011 12:12 PM
I have an idea...it's the same as your idea . Set some timeout and clear errors if you get error 56. I would not suggest setting it to 2 minutes though, because, like you said, in that case your program could potentially take 2 minutes to stop. I'd set it to something like 200 ms (random value I picked.).
02-11-2011 04:16 PM
Thanks for confirming my thoughts, imstuck. I guess thats my only good option.
