vision assistant loses match,
hey guys , is the a way to buffer the previous value of my y axis from Vision Assistant , if i lose a match .
ie if y = 52 .then is i lose the image match , how do i keep y at 52 until it finds the image again? an internal data buffer of such??
(1,961 Views)
I'm Chiara, an engineer at NI, and I'll be trying to help you out with this.  I think what you probably want to look at using is a Shift Register on your loop around the vision assistant, to record the last y value.
Some further information on shift registers can be found here:
Tutorial:  http://www.ni.com/white-paper/7592/en/
Community Example: https://decibel.ni.com/content/docs/DOC-6264
Please let me know if this helps.
Best wishes,
Chiara
Chiara A
Applications Engineer with NI UK & Ireland
(1,926 Views)
hey chiara, thanks for the help.
so far i have a shift register, that has a 3 reading buffer on it so if the image goes missing it has 3 samples to re-find it before it zero's
(1,921 Views)
Great, I'm glad that you found the information useful and best of luck for your continued programming in LabVIEW.
Best wishes,
Chiara
Chiara A
(1,916 Views)
