02-10-2016 10:06 AM
I just want to compare two strings . One from the string constant given by the user and the other from the vision assistant. Used equal comparator but its shows fail even for true conditions ..
02-10-2016 10:13 AM
Maybe you need to use the "Trim White Space" from the string palette???
Show some code if this doesn't help.
02-10-2016 10:31 AM
I Tried trim white space but no solution..
Here i attached my program
02-10-2016 10:49 AM
Ok, I'm sorry to say that I don't have the vision module, but the code you posted has no comparison going on. Post some code of the comparison that doesn't work.
