06-16-2015 10:12 AM
I am trying to learn DAQ on labview. So, I made a basic digital input vi, with a virtual digital input device. For some reason I cannot get it to output anything other then zero, but when I run the daq assistant (when setting up daq assistant) the boolean values toggle between 0 and 1. But, in my VI I cannot get any input other then zero.
I have attached my VI.
Thank you
Solved! Go to Solution.
06-16-2015 10:31 AM - edited 06-16-2015 10:32 AM
You should wire up your stop button to the Stop input on the DAQ Assistant. You are openening and closing the task each time when you do not do that. I think that is also resetting the toggling of the simulated device.
06-16-2015 10:40 AM - edited 06-16-2015 10:41 AM
That did the trick.
So, if I didn't wire the stop button to the stop daq assistant terminal, the daq assistant is basically triggering on and off?
Thank you
06-16-2015 11:05 AM
Not quite. The task was being created and destroyed with each iteration of the loop. By telling the DAQ Assistant that you are not stopping, it leaves the task open.
