05-14-2014 10:28 AM
I have a vb.net application we are distributing and it calls a couple of vi's that I have bundled into a dll. Obviously we need to have the runtime engine installed on the machines we are deploying this application to. I was wondering if there was a registry entry or some other way to determine if the runtime engine was already installed on a windows machine.
I know I could build my own installer and set registry keys, however the minimum runtime engine installer works and it is only 28 mb, where the smallest installer I have been able to build is about 140 mb. So, as I said I am faced with two options, figure out a way to build my own minimum installer or figure out how to determine if the standard NI minimum installer is already install.
I haven't been able to find anything relating to this in my searches.
Eric.
Solved! Go to Solution.
05-14-2014 11:17 AM - edited 05-14-2014 11:19 AM
There may be a more elegant way, but you could always check <Program Files>\National Instruments\Shared\LabVIEW Run-Time\####
EDIT:
Oh I found it by the way (with a little Regedit.exe searching): HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\LabVIEW Run-Time\####
*where the pound signs represent the version number.
05-14-2014 11:28 AM
Indeed the registry is the way to go. Here is a post on LAVA I did a while ago where I use AutoIt to get the different versions of LabVIEW installed (development or just RTE) and then run the appropriate version for the one installed.
http://lavag.org/topic/17803-run-exe-based-on-installed-run-time/
The source code is included so you should be able to understand the registry keys I read to find the versions installed.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
05-14-2014 11:34 AM
Thank you everyone. Found the registry keys and that is exactly what I was looking for!
