Hi Guyzmo,
I have just had problems with cvixml labwindows functions.
In fact, in my case, my memory problem doesn't occured in debug mode but it occurs in release mode!
The code of the two executables (release and debug) is exactly the same and it is launched from the same directory!
The lines with the problem are the following:
" if ( xml_error = CVIXMLGetElementTag (parent_element, name))
return xml_error;
CVIXMLGetNumChildElements (parent_element,&nb_child); // the fatal error occured here
If I insert a function between the two lines, a function that displays a message box or that writes in a log file, the error doesn't occur !!?
It is really amazing !
So I insert my log file writing function before the CVIXMLGetNumChildElements and now, I have no problem 😉
Sgs
