07-26-2012 09:04 AM
I am trying to get two boolean buttons to reset when the value of a ring menu changes. For this I am using an event structure set to execute with a ring value change. However I have other code that needs to be executing while the event structure waits for the value change. I place my event structure inside the while loop the buttons reset as expected but my other code does not run (except at the moment of value change). If I place it outside the loop the rest of the code functions as expected but the buttons do not reset. Any help you can offer is much appreciated.
Solved! Go to Solution.
07-26-2012 09:11 AM
ADD TIME OUT EVEN AND GIVE 100 MS TIMEOUT.
Add event case-application-timeout
07-26-2012 09:15 AM - edited 07-26-2012 09:16 AM
I knew there had to be an easy solution. Thanks so much!
07-26-2012 09:18 AM
try this
07-26-2012 09:19 AM
Oh! I am late!
but i gave a different solution, though
