I try to make a multiplot with buiding XY graph express VI, but it doesn't work.
See attached. Array 1 is a 1-D array as X input. Array 2 is a 2-D array containing 2 rows.
I wish plot array1 (x) vs. Array 2-1st row( y1), and array1 (x) vs. Array 2-2nd row( y2) in one graph. But, there is only array1 (x) vs. Array 2-1st row( y1) plotted.
How can I make multiplots with buiding XY graph express VI?
It's quite easy: make it without using ExpressVIs...
ExpressVIs are made for a purpose. You can edit some properties, but not all. As soon as you need more options you have to leave the easy way of configuring ExpressVIs and do some real programming on your own!
Best regards, GerdW
You mean XY express VI doesn't accept that kind of input for multiplot, and the only way is to split 2D array(y1, y2 ...) , bundle them into xy pairs and then build cluster array for XY graph input?
