When you plug the USB/RS232 device into a USP port, Windows connects to it and assigns it a COM port number. You can go to the Device Manager and by looking under the "Ports" section you can see what port number it was assigned. A couple things to note:
First, the numbers will not simply a continuation of the port numbering that is already in the computer. By this I mean that if you have ports 1 and 2 in the PC, the one you add might appear as port 7 or 9 - I'm not sure why the gaps in numbering exist.
Second, depending upon the drivers that come with the USB/RS232 device, moving a given device to a different USB port may result in a different COM port number being assigned to it. LIkewise plugging a different USB/RS232 device into the same USB port may result in a different COM port number being assigned to it.
Mike...
