03-27-2014 08:34 AM
Hi all,
I'm following the National instruments procedure to operate a fan using an SSR with a USB DAQ-6008. http://www.ni.com/example/31411/en/#toc5
I need a minimum of 3 volts from my daq to control. This should be no problem as I can get up to 5V. However when I measure using a voltmeter I get 5v but when I connect the wiring for some reason it will only give me 1.49V. Disconnect the cable again it measure as 5v.
Has anyone any idea what Im doing wrong ?
cheers
S.
03-27-2014 09:09 AM
Hi
The output current drive for Analog Output is 5 mA. My guess is, that your device is using to much power.
03-27-2014 09:25 AM
H Alex,
thanks for your reply. I suppose whats really thowing me is that if I go into MyDAq I can manually request 5 V and teh fan works. However run it in a VI and no joy, back to 1.49 it goes...so weird.
many thanks
S.
03-27-2014 09:26 AM
03-27-2014 09:47 AM
thanks for your reply, I have a Fentek SSR-25 switching a 230VAC circuit with now problems. The issue is with the SSR mentioned in the NI procedure http://www.ni.com/example/31411/en/#toc5
03-27-2014 09:55 AM
03-27-2014 10:00 AM
Denis,
the 6008 can switch the SSR when I manually input 5VDC in the MyDaq interface. But when I run it in a VI it only outputs 1.49V.
03-27-2014 10:05 AM
03-27-2014 10:08 AM
