Hello kas,
Just for some further clarification, using the DAQmx Base Configuration Utility, you can add individual lines to a digital read or write task. By setting the line mask in the
Line Selection tab, you can select which lines to include in your task.
Also, if you are using the USB-6008 on either Windows or Linux, I would highly recommend using the NI-DAQmx driver to program your application rather than NI-DAQmx Base. The full NI-DAQmx driver has a lot of functionality that is missing from the NI-DAQmx Base driver. If you are currently using NI-DAQmx Base and want to switch, check out the following KB for further instructions:
Why can't I see my USB-6008, -6009, or -6501 under "DAQmx Devices" in MAX after installing NI-DAQmx ...Best regards,
