urgent - path planning
greetings fellow programmers,
I am working on DANI robot, and created a MAP of a room, by controlling the robot's movements using Labview. I have used maxsonar EZ1 sensor. Now if I have to move it from a point A to point B in the map, how would I do so?
NOTE:Assuming there are moving obstacles (or slight change in the environment), I will use the same sensor for obstacle avaidance as well.
Any information will be appreciated.
Danish
(2,307 Views)
Please do not create multiple posts. You are already being helped in your original thread: http://forums.ni.com/t5/LabVIEW/Maapping-using-Maxsonar/td-p/1997827. Keep all discussion in ONE place.
(2,286 Views)
Link doesn't work, (you have a . at the end) http://forums.ni.com/t5/LabVIEW/Maapping-using-Maxsonar/td-p/1997827 does though
(2,254 Views)
Thanks. I hate this forum software.
(2,245 Views)
oh am sorry, the topic was different, so i though of addressing it seperately. But thank you for being kind enough to inform.
Cheers
(2,237 Views)
