07-27-2005 01:04 PM
07-27-2005 01:06 PM
Hi SAL,
Did you re-install the Traditional NI-DAQ driver when you upgraded your computer?
Ryan K.
07-27-2005 01:21 PM
07-27-2005 03:02 PM
Hi Ryan and Ed,
Well here is what I did. I copied the existing labview program running with win98 on the other hard drive as a back up and tried to upgrade the existing drive with win XP. After windows installion upgrade, the program generated errors.Saying broken.....here are some of the errors.
poly VI..AO update channel, vi, polymorphic subVI is broken
poly VI, AI acquire waveform.vi..subvi not executable....
AO group config.vi..
AO hardware config.vi..
AO single update...AI control
It seems that with the window upgrade all my programs in the labview is generating errors..with broken links...I have no clue what is going on..
But if i switch the hard drive with win98 loaded the same program works. fine..
What is wrong? How do i solve it?
sal
07-27-2005 04:18 PM
07-28-2005 07:19 AM
07-28-2005 01:52 PM
08-02-2005 09:04 AM
