updating combobox
Hello Every one
I am trying to programatically update my combobox using string[ ]. It should be updated with .csv files saved in a particular forder but it is updating with all the forder names on my desktop. I am unable to select the pirticular folder which i want to update in my combox....... I dont know whats the mistake i am doing......coud someone help me please. Thankyou in advance
Regards
Pratheek
Message 1 of 9
(2,841 Views)
A few things.
You're using the System Path function for your directory. It sounds like you want to use a file dialog.
You probably want to update the ComboBox in a different event than on a value change. Otherwise you're always going to get prompted for the selection directory.
Also, you don't need the reference control. You could just link the property node implicitly for updating the strings.
Message 2 of 9
(2,834 Views)
hi Taki1999
Thanks for the immediate reply......I am sorry I didn't get ur point....i am fairly new to labview. Could you please explain it more clearly. I tried it with the recursive file block.......but even then i have the same problem....
Message 3 of 9
(2,828 Views)
Accepted by topic author pratheek
You could just use a path control on the front panel.  Then you just type in the path your want or use the browse option.  Then use the Recursive File List function to limit the returned files to *.csv.
GCentral
Message 4 of 9
(2,816 Views)
OK.
First thing: Which directory do you want to scan for files? Do you want it to be user selectable?
If you want it to be user selectable, use the File Dialog under File I/O->Advanced instead of the Get System Directory.
What sort of problems are you running into with the List Folder function? Are you getting too many files? Wrong files? Are you sure your wire is connected to the filenames output instead of the foldernames output?
EDIT: Crossrulz solution is probably closer to what you want.
Message 5 of 9
(2,815 Views)
got it......Thanks alot Taki1999 and
Message 6 of 9
(2,798 Views)
One more small doubt.......it is displaying the whole file path in the combobox.....is it possible to disply only the file name in the combobox with out any extensions ?
regards
Pratheek
Message 7 of 9
(2,792 Views)
FOR loop with a Strip Path inside.
GCentral
Message 8 of 9
(2,787 Views)
thanks alot....
Message 9 of 9
(2,781 Views)
