06-26-2015 10:41 AM
I am trying to plot this data with multiple channels and a big buffer display when I select more than one channel, the starting point of the channels have a gap. I am not sure why is this happening, please help. I think the problem is from the buffer but I cant seem to fix it though I tried to forced them to start at the same timestamp using the align timestamps VI, it still did not work. The Vi is attached
06-26-2015 05:16 PM
Please see my comment to your subsequent post. I gather the Moderators consider it bad form to post a new topic that is essentially an "add-on" to an existing topic (I've seen Cross-Post notations a few times), so you should consider simply "Replying" to yourself to ask an additional question.
As I noted in the subsequent post, it is not clear (just by looking at your code) what you want to do. Spending the time and effort to write it down clearly (for us) might, indeed, clarify it for yourself, generating that hoped-for "Aha!" Moment.
