unit test rename
Following the discussion from here:
http://forums.ni.com/t5/LabVIEW/Cannot-rename-lvtest-file/m-p/2621909/highlight/true#M785332
I end up creating several dummy unit tests in the lvproj then exit and restart labview and then properly set up these dummy unit test with proper names.
How much is the Unit Test framework in $$? Pretty annoying one cannot expect a simple rename function from $$.
Has someone found other workarounds in the meantime?
(2,922 Views)
Accepted by topic author Labuser16383
HI,
the expected way to create tests is not by right-clicking "my computer" ...
Here is the official help file:
Creating Tests (Unit Test Framework Toolkit)
By creating the unit test from the VI the renaming should be no problem!
Best,
Anna
Anna Vogl
Certified LabVIEW Developer
(2,857 Views)
Thank you for the hint. I will take care of that from now on.
However how should one know which is the expected way if it is not explicitly written?
I mean right clicking on "my Computer" is not an avantgardistic idea.
(2,824 Views)
