02-18-2013 12:24 PM
I buy the software from our university webstor and download all the file from it.
when I trying to install the labview 2012 in my window 7 64 bit systems:
1) when I click autonrun.exe and it show install, but I click intall, there is not any response;
2) I directly click the setup.exe, it shows that:""
But in our lab, we have install the same file on windows 7...
2) if I run setup file as adminstrator, it shows:
3) i have check I can run other exe file
Solved! Go to Solution.
02-19-2013 08:06 AM
Have you properly extracted all the files from the downloaded installer zip file?
02-19-2013 12:17 PM
Yes, I use the extracting tool of Windows to extract the file.When I use winrar and it fix the problem.
Thanks a lot.
Best,
Xiaochun
07-18-2013 12:53 PM - edited 07-18-2013 12:54 PM
labview is very easy to install. just follow the link and follow instructions.
http://labview101.blogspot.com/2013/07/how-to-install-ni-labview.html
07-19-2013 01:33 PM
You are not answering the original question, but just spamming your web page here with a very generic answer.
(your link is also malformed and broken)
07-19-2013 10:32 PM
The English language used on that webpage is being abused also. It needs some serious grammar checking.
01-30-2016 09:03 AM
hello,
i need some help here 🙂 could anyone help me with this problem ?
i'm installing Lab View 2014 64-bit on my windows 10 64-bit too, but the LAB VIEW wont be installed. What should i do to solve this ?
thankyou 🙂 🙂
01-30-2016 11:15 AM - edited 01-30-2016 11:18 AM
EDIT: even a duplicate hijack 🙂
http://forums.ni.com/t5/LabVIEW/Labview-2014-DSC-install-error/m-p/3245948/highlight/true#M945545
01-30-2016 11:31 AM
@kuroko wrote:i'm installing Lab View 2014 64-bit on my windows 10 64-bit too, but the LAB VIEW wont be installed. What should i do to solve this ?
For, the images, it seems that LabVIEW (notice the correct letter case!) is already installed. Was it ever installed on this machine?
Is there a good reason you are installing LabVIEW 64bit and not 32bit?
01-31-2016 09:28 PM
LV 2014/Windows 10 combo isn't even supported. See here.
