09-09-2014 10:38 AM - edited 09-09-2014 11:01 AM
Hello everybody,
I´m using a camera from Thorlabs (DCC1645C) for surface measurements. I´m trying to use it with Labview, I´ve got the drivers installed but I do not have any idea how to use them (since "drivers help" seems not to work).
Has anyone ever used this camera? Any help is welcome!!
09-09-2014 10:47 AM
@lacorgui wrote:
Hello everybody,
I´m using a camera from Thorlabs (DCC1645C) for surface measurements. I´m trying to use it with Labview, I´ve got the drivers installed but I do not have any idea how to use them (since "drivers help" seem not to work).
http://www.thorlabs.de/thorcat/ITN/DCC1645C-SoftwareManual.pdf
09-09-2014 11:00 AM
Thanks nyc,
I know how to use this application. However my purpose is to implement the use of the camera in Labview using the drivers installed instead of using the application.
09-09-2014 11:08 AM
@lacorgui wrote:
Thanks nyc,
Drivers are not meant to help you learn how to control the camera.
09-09-2014 11:16 AM - edited 09-09-2014 11:16 AM
I know, I read the manual and other .pdf files in order to understand the camera way of working. In fact, I´ve use the camera before, taking pictures and videos. However, due to my research job, I must implement, at least, the viewer of the camera in a Labview interface. For that, I think using drivers is the best option since they are based on VISA resources.
I´ve found an old post (getting started with thorlabs lc1-usb (2007)) with some examples but unfortunately vi examples files are not in the server any more (old_example).
Hope to find a way to do it!
09-09-2014 02:20 PM - edited 09-09-2014 02:22 PM
You may want to try installing the older UC480 version 4.20 software.
http://www.thorlabs.de/software_pages/ViewSoftwarePage.cfm?Code=ThorCam
It includes a manual about the LabVIEW drivers which are *not* included. However the explanation may match the VIs you have that are installed with the newer software.
It also includes a VB.NET example using ActiveX. That may be translateable into LabVIEW.
By the way, there are most likely a lot of helpful resources installed on your PC.
Look in the Program Files directory under Thorlabs.
11-21-2015 04:21 AM
Upon installing the Thorcam software, the labview VIs are installed as well.
usually they are found in the following
directory C:\Program Files (x86)\Thorlabs\Scientific Imaging\DCx Camera Support\OtherDrivers\LabVIEW\8.x_32-bit
hope this helps
