typedef updates don't update callers when using save as
I have a typedef that holds configuration data for my system...this typedef is used by many VIs in my application.
This typedef will change over time as I add/delete configuration parameters, but I would also like to retain old versions of the typedef so that I can retrieve old configuration information.
I accomplish this by always using "Save As" whenever I update the typedef, and saving new versions with a different name. For example:
ConfigData_v1.ctl
ConfigData_v2.ctl
ConfigData_v3.ctl
What I expect to happen is that I can open up a current version of the typedef (let's say ConfigData_v1.ctl), make changes, then select "Save As"...I do *not* check the "Save a copy without updating callers" checkbox because I *do* want all callers to now point to the new typedef that I will be saving as ConfigData_v2.ctl.
I've noticed, however, that if I start LabVIEW and first open up ConfigData_v1.ctl, make the changes, select "Save As" (not checking "...updating callers..."), and then close ConfigData_v2.ctl (which was opened as ConfigData_v1.ctl)...when I open any of the VIs that use(d) the ConfigData_v1.ctl typedef, they have not been updated to point to ConfigData_v2.ctl.
Is this because VIs which use ConfigData_v1.ctl were not loaded into memory at the time when I made the change to the typedef? Strange.
Thanks!
BTW, if you're curious about how the data is managed, I have written a VI that pulls in data that conforms to an old version of the typedef and extracts the data into a new version of the typedef. This allows me to update my configuration typedef and propagate any saved values from old to new.
(2,129 Views)
This is LabVIEW 7.1
(2,120 Views)
"Is this because VIs which use ConfigData_v1.ctl were not loaded into memory at the time when I made the change to the typedef?"
In short: Yes. Only the callers in memory are updated.
Fading out. " ... J. Arthur Rank on gong."
(2,106 Views)
