01-18-2016 03:43 PM
Hello what do I need to change to delete the first 20 rows of the tdms file instead of the last 20?
01-18-2016 08:06 PM
Hi reggie2016,
TDMS Delete Data function can be used to delete data from multiple channels. But if you only wants to call the function once, the number of samples to be deleted from each channel should be identical; the position from where (start or end) to delete data in each channel should also be identical.
Just to clarify, TDMS Delete Data not supports deleting data from the middle of a channel, since data continuity should not be broken.
Hope this could help.
Jie
NI R&D
