03-15-2010 10:09 AM
03-15-2010 10:14 AM
Hi
Check attached VI
http://decibel.ni.com/content/docs/DOC-2401
03-15-2010 12:08 PM
03-15-2010 12:12 PM
03-15-2010 12:42 PM
akakiev wrote:
to Anil Reddy: GmailLV86.vi is working. It is nice. But: 1) if I don't want to use gmail?
Just change the smtp server.
akakiev wrote:
2) Why "SMTP send email" doesn't work? Can I use standart vi-instruments in "SMTP" group in "Data comunication" in LabVIEW?
The most likely reason is that the server you are trying to use requires authentication. Most SMTP servers nowadays are like this. The SMTP VIs that come with LabVIEW do not support authentication.
03-15-2010 12:56 PM
да, похоже что сервер на рамблере все таки требует авторизации (рамблер помощь). авторизация не включена в выполняемые функии SMTP Send Emai VI, поэтому придется использовать вышеуказанный пример.
удачи!
03-15-2010 04:07 PM
08-17-2010 03:50 AM
Hello
i get the error -7 when is send this mail.
_tmp1 = InetSendMail ("smtp.gmail.com", "supersnowV7@gmail.com", "info@technofase.com", "Test Mail", "Prova", "");
I create the mail with gMail but i can't send it.
I try to send the same mail with LIVE MAIL and i send it (so no problem by the Mail Server).
Can somebody help me ?
08-17-2010 09:37 AM
@TECHNOFASE wrote:
Hello
You have posted to the wrong forum. InetSendMail is a LabWindows function. This is the LabVIEW board, which is the graphical programming language. You need to post in the LabWindows board, which I see you've already done
