trig wrong result
Hi. I'm sure that is a simple representation setting problem. Can anyone help me? The PI number it appear to be in other representation than the result from the arctan function. The subtract shoul be 0 theoreticaly.
Thank you.
(2,363 Views)
Hi sorinpetrila,
Yes, you're right - in a perfect world.
But using floating point numbers isn't far from perfect! Please read the basics on using floats and their shortcomings - there are nice articles on Wikipedia…
(2,347 Views)
Thank you for the fast reply.  But how can I fix this? This subtraction affects other results that come after.
(2,338 Views)
Hi sorinpetrila,
you cannot FIX this issue - you have to deal with it!
There are so many threads on the topic of floating point precision (aka "rounding errors" aka "unexpected results" aka "why does adding 0.1 ten times doesn't result in 1.0" aka …), please read them! Whenever you use floating point numbers to calculate any numbers you are responisble for paying attention to imminent rounding errors!
In your case a simple comparison may work:
IF abs(result(subtraction)) < needed precision
  THEN result = 0
ENDIF
Another good description of the topic
(2,329 Views)
Thank you. I was searching for this answer.
Best regards.
Sorin
(2,303 Views)
