06-02-2008 12:44 AM
06-02-2008 03:34 AM
Hai,
could you please post the error code or give a screenshot of it.
Mathan
06-02-2008 03:43 AM
Hi!
"The Error code is -2147417851 occured at the server threw exception"
06-02-2008 03:50 AM
Try a search in the forum with the keyword - server threw exception. you can get a couple of solutions.
see here
Post if still problem persists.
Mathan
06-02-2008 04:22 AM
06-02-2008 05:00 AM
I assume you're talking about this, so my guess would be that you are using it wrong. That specific ActiveX object only uses a single tray icon and adds entries to it unless you destroy it. The ZIP file I linked to includes an example of how to create and destroy the object. Make sure you use it the same way.
If you need to have different icons, you can try using the .NET framework. If you search the LAVA forums, you should find an implementation which does this using .NET.
If after trying all that you still have a problem, you should upload your code.
