06-09-2015 10:11 AM
Solved! Go to Solution.
06-09-2015 10:20 AM
You'll need to push your data from your LabVIEW application to a server:
- HTTP Client VIs
- TCP/IP
- WebSockets
Server could have a LV application on it, or you could use a web server with a scripting language (e.g. PHP/ASP/Node.js).
You'll need to write something on the server to listen to your LabVIEW application and hold the data:
- Database
- File
- Memory
You'll need to write some interface/API for pushing/retrieving the data - e.g. JSON/POST/XML - take a look at 'RESTful APIs'.
The choice of which of these to go for depends on how 'real-time' you are talking - how often do you want to update the data, the latency etc.
If you don't want to do all of this yourself, there are 3rd party providers that can store this sort of data for you - there's a free (but limited) one run by SparkFun - https://data.sparkfun.com/ but I'm sure there are other services.
06-09-2015 10:39 AM
06-09-2015 10:47 AM
06-09-2015 10:55 AM
06-11-2015 01:48 PM
The NI Cloud Dashboard may also be helpful
