09-15-2014 04:41 AM
After updating to LV 2013 the tpc-2012 in my labview-Project is marked "unsupportede device". How can I change this? Must I updated the software? Where can I find actual software?
Christian
Solved! Go to Solution.
09-15-2014 08:05 AM
What's a TPC 2012?
09-15-2014 08:10 AM
a touch-panel computer working with windows ce. In LV 2009 I have integrated it in my project and after the update to LV 2013 it don't work anymore.
Christian
09-15-2014 08:35 AM
Christian
How exactly is it "integrated"?
09-15-2014 08:39 AM
it appears in the project file as for example the crio device. I can deploy files to it work with it as with any other device in the project tree.
09-15-2014 08:57 AM
look here
09-15-2014 09:24 AM
You will have to contact NI if you want to use the TPC-2012 with LabVIEW 2013 http://sine.ni.com/nips/cds/view/p/lang/en/nid/209858
Starting with LabVIEW 2014, it looks like the TPC-2012 will no longer be supported. http://www.ni.com/white-paper/5868/en/
09-15-2014 09:26 AM
that means no update for Labview anymore.
09-15-2014 09:30 AM
That is what it looks like. They want you to upgrade to TPC-22xx for future versions of LabVIEW starting with LabVIEW 2014.
