11-17-2014 11:42 PM
hi
1. im attaching a simple password vi with 'volt' being its password. i have set a key focus property for the indicator control and toggle key binding property for enter button using enter key. when i press enter key the indicator doesnt read any value typed in it and shows it as blank. it reads the correct value of indicator only on clicking the enter button using mouse
im unable to figure out why it is not reading the indicator value when i press enter key
i think it has something to do with the toggle key binding property
2. in the same vi there is a string control A. im unable to create its local variable. why?? is it possible to block someone from creating a local variable ??
thanks in advance
rahul garg
11-18-2014 12:15 AM
Right click on your string and select "update value while typing" this will solve your password problem.
right click on string "A" and select create local variable option.
11-18-2014 12:15 AM
Hi, gargrahul,
First, you can probe your string to see what value it output.
Then you can check the string property of Update Value while Typing, and you can realize the string value didn't change if it is unchecked.
I'm confused with your second question since I can create a local variable of String A in your VI.
Could you give more information?
11-18-2014 09:17 AM
