timestamp surprise on cRIO
Hi all,
I'm having trouble with timestamp formating on my cRIO.
I saw in MAX that cRIO doesn't support DST, I assume that why I get 1h difference between the time stamp and the string formated value, right?
What can I do to have the string match the timestamp display?
Cheers
Epictetus
Antoine Chalons
Message 1 of 14
(3,267 Views)
Nothing very easilly.  Suggestion: work in UTC not local civil time.  Those silly French guys had a good idea when they standardized UTC to be the same everywhere and consistant in progression (A second here or there a couple of times per decade isn't really that much trouble right?)
"Should be" isn't "Is" -Jay
Message 2 of 14
(3,258 Views)
Hi
I didn't found your function, but there are also another ones that might be usefull for you, for example you have the:
Or there is another that is more direct. The next image shows you both functions to see if there is one that fits to your project.
If your question is specifically because you need to use that function, can you tell me the name so I can search it in a better way?
Regards.
Message 3 of 14
(3,252 Views)
@Luis32 wrote:
Hi
Regards.
Try searching "Scan from String".
Message 4 of 14
(3,239 Views)
actually the primitive I'm using it "format into string", right next to "scan from string" in the "string" palette.
I've asked if UTC would be ok, apparently when many different integrator have to put their results into one same container they tend to meet on UTC. I'm waiting to hear back on that suggestion.
But really... NI's RT targets won't support DST... last time I came to NI week all I could hear was how green NI was and how much energy I could using LabVIEW and blablabla... but daylight saving time, no!
Go figure the **bleep** out...
Epictetus
Antoine Chalons
Message 5 of 14
(3,218 Views)
hey... I didn't type "bleep"...
Epictetus
Antoine Chalons
Message 6 of 14
(3,216 Views)
https://www.youtube.com/watch?v=vbZhpf3sQxQ
dare I ask what's the list of words that will be bleeped?
Epictetus
Antoine Chalons
Message 7 of 14
(3,211 Views)
oh and by the way.. just because life is a joke, I have this issue at a swiss watchmaking customer.. the kind of watch that costs more than a car... how do you want them to take LabVIEW seriously??
Epictetus
Antoine Chalons
Message 8 of 14
(3,204 Views)
@Luis32 wrote:
http://digital.ni.com/public.nsf/allkb/2DA96C2456C7667B86256F90005E3049
Hi TiTou,
As mentioned in the KnowledgeBase you can enable the DST for your cRIO in MAX under Time Settings by checking the “Automatically adjust clock for Daylight Saving Time” box.
Let me know if that worked for you.
Cheers
Maha
AE Germany
Message 10 of 14
(3,159 Views)
