time management
Hi all,
hope everyone is well.
I have produced a VI to log and control a mass flow controller an log the pressures in a vessel.
This VI work fine and logs everything i need but the time value is relative to when I do the test for example like 10.43:53 ( which is 43 minute past 10 in the morning) what i would like it t o read would be reletive to the actual time it takes to do the test 1,2 3,4secs and so on.
could anyone assist?
Here is the VI in all it glory
Its in TOP LEVEL so should all be there
P.S if anyone thinks it can be done better plaese feel free to have a go as I am only a novice an need as much help as I can get
Many many thanks
(2,161 Views)
Sounds like you need to switch to relative time. Right click on the chart or graph and select properties, Format and Precision, Time (X-axis), then relative time.
(2,154 Views)
