text to text machine translation
Hi, I'm looking for a VI that can translate an entered string to an equivalent value in a list of strings and display this equivalent string
E.g. If I type in "a" it would display "Alpha" and if I type in b it would display "Beta" and so on.
Message 1 of 22
(2,947 Views)
I suggest to use variant attribute for that, if you look it up you should find interesting results.
Epictetus
Antoine Chalons
Message 2 of 22
(2,945 Views)
Here's what I mean, hope this helps.
Epictetus
Antoine Chalons
Message 3 of 22
(2,940 Views)
I don't see in what way "a" is equivalent to "Alpha" and why you call this a "translation"?
Please clarify. How does your list of strings look like? Is it a list of keys and their values, for example?
Message 4 of 22
(2,936 Views)
One serious flaw here is the fact that you have two controls with the same name. This can lead to endless confusion, and accidental mistakes, especially if you use local variables and property nodes.
The variant attribute is sound, though. I use it all the time, e.g. for associative arrays. 😄
Message 5 of 22
(2,932 Views)
Very true, I went a bit to fast...
Yes, it's really fast, I love it!
Epictetus
Antoine Chalons
Message 6 of 22
(2,929 Views)
Thank you
I'm new with labview. What does the variant do exactly? Because I'm trying to replicate the vi you showed except that it has to permanently save the added translations even if the panel is stopped or closed.
Message 7 of 22
(2,924 Views)
Oh... that won't happen with the VI I gave you.
But you could add some code at the end to save all the attributes into a file and at the next start load the attributes from the file.
I'm home now so I can do it... but you could have a go, it's not that hard, and come back here if you have specific questions.
Good luck!
Epictetus
Antoine Chalons
Message 8 of 22
(2,914 Views)
Why is this message thread in the Feedback forum?  It isn't a conversation about the operation of the forums.
It should be moved to the LabVIEW forum.
Message 9 of 22
(2,911 Views)
i've asked the moderator to move it to the lbview section already 😉
Epictetus
Antoine Chalons
Message 10 of 22
(2,905 Views)
