03-10-2015 08:39 AM
How do I install the DMM driver?
03-10-2015 09:00 AM
My bad, in my last post I included the following error which was related to an RCI
connection and not related to the topic...
If I run the Vi on this system it give me the following error:
This is the error message that I meant to post:
03-10-2015 09:02 AM
Is there a way to change the version of labview in the teststand labview environment?
03-10-2015 09:36 AM
03-10-2015 12:58 PM
Thanks Dennis
I looked at the MAX and I am seeing several versions>>>
03-10-2015 01:13 PM
03-10-2015 01:22 PM
No, when I made the deplyment of my VI, I added all of these to it so that they would load on my test PC.
Then when I deployed it they were all copied over and once they were, I received critical update notifications.
What I am missing is some good instructions on how to set this test PC to run teststand and have it launch labview VIs
with only a Time engine installed...
03-10-2015 03:12 PM
03-10-2015 03:46 PM
At first, I only installed the Teststand deployement license and I put the Labview run-time engines on this test PC with a deployment
of my MeasureVoltageread.vi I did not know what I needed so I added everything that I could...
When the Test stand would not launch the labview VI, I started to download drivers and updates and that is how I got to where I am today...
No closer to being able to launch my Labview VIs from teststand.
03-10-2015 03:58 PM
