testing if one key of the keyboard is pressed
Hi everyone,
As is montionned in the subject, i want to test if a specefic key of the keyboard is pressed, for example i want to know if the key "A" is pressed or "Z" or "3" ??
can anyone help with this please
Best regards
(4,457 Views)
Accepted by topic author Brainiac91
Use an event structure, similar to this.
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(4,441 Views)
Option 1:
Labview event structure, register event for This VI -> Key down. Then check by ascii code.
Option 2:
Check  keyboard using Connectivity -> Input device control > Initialize keyboard function and Acquire input data function.
I use 2 if I need to check once, or to verify button is still pressed, because event is registered for VI, so if it is not in focus, it will skip it.
(4,437 Views)
thks aputman for the solution it works perfectelly, but there is a little issue, i want that the booleen turns to false when i release the key, or it turns automatically to false after a bit of time, is that possible ??
(4,392 Views)
Hi Brainiac,
did you play a little bit with this event structure?
Did you notice the "key release" event?
Simple pseudocode:
ON EVENT(key release) DO boolean := FALSE
(4,383 Views)
Hi
In fact it is my first time using the event structure, but i found a soluion for the problem, it can be handled with the timeout event, thnks for answering anyway 😉
(4,378 Views)
I wouldn't recommend putting the key up detection in the timeout case.  What happens if you decide you want to make the timeout longer for some reason?  There is a specific event, as Gerd suggested, for detecting when the key is released.  Use it.
aputman
(4,343 Views)
