temperature data with NI USB 6218
That was what I had in mind. Maybe using the 5V available in the DAQ. Just wondering if there was an example.
Message 11 of 15
(653 Views)
Here is a youtube video made for a MyRIO but the concepts are all the same, apply a static voltage, use a resistor and capacitory, and sample accordingly.  They used two analog inputs, one to sample the static voltage applied but if you know this is a static 5V you can probably put a constant in there, and lose some accuracy.
https://www.youtube.com/watch?v=xi0VIpGpf4w&feature=youtu.be
Page 30 of the MyRIO essentials guide goes into more detail.
http://www.ni.com/academic/myrio/project-guide.pdf
Message 12 of 15
(643 Views)
Hello Mebels,
It is possible to measure temperature from an RTD sensor using your USB-6218. On the following article you can check some connection configurations using 2-, 3- and 4-wires.
The easiest one to set is the 2-wire connection.
http://www.ni.com/white-paper/3643/en/
David M.
Message 13 of 15
(627 Views)
I don't belive the 6218 can act as a constant current source, can it?
Message 14 of 15
(615 Views)
Message 15 of 15
(591 Views)
