10-21-2010 08:16 PM
I am currently modifying my old program to log data to the TDMS files instead of text files. The file size is much smaller and writing speed is reasonable. The problem is that when I read the TDMS file, it seems very slow (11.293 seconds), and acquires nearly full CPU capacity (97%) for couple of seconds, which will cut the user interface communication. The file size is below 9MB with 37 columns and 30000 rows. I am not sure it is normal or not, just feel little bit hard to believe. The same program working fine on my laptop (1.281 seconds), but obviously it has more powerful CPU (dual 2.5GHz instead of cRIO's 800MHz). Waiting for any luminous idea, thanks.
10-21-2010 09:24 PM
A few ideas and notes:
10-21-2010 11:02 PM
Hey Jarrod
Thanks for the quick reponse.
1,2,3 and 6 are very helpful and will give a go.
Answers for the rest of questions:
4. They are all same length.
5. Yes, they are written as doubles.
I will keep you posted, thanks again.
10-22-2010 01:49 AM
I tried to use TDMS defragment function and big-endian format file, but none of them seems bring too much difference.
I accidently found out that by choosing decimal mode instead of interleaved can speed the program from 10xxx (ms) to 17xx (ms), which is good enough to me, but it will still kill the front panel communication for couple of seconds. So I guess I will try to read less amount of data each time instead.
10-22-2010 03:58 AM
What do you mean by
@tarzanyu wrote:...but it will still kill the front panel communication for couple of seconds.
Are you viewing the "Front panel" of the VI runing in the RIO ?
10-24-2010 05:04 PM
Yes, I am still tuning the program for performance inprovement purpose when it is running on the cRIO, so I am viewing the front panel of the top level VI to check some performance indicators. Everytime when the program opens the TDMS data file, my laptop will lose the connection to the cRIO and retrieve it in about 10 seconds.
10-24-2010 06:14 PM
I decreased the number of data to read for each channel, and the front panel disconnection problem disappeared. It seems just a cRIO and network hardware limitation issue. Again thanks for all the replys.
10-26-2010 02:29 AM
The only limitation is that when you are viewing the Front Panel of a cRIO vi it will have a very low priority in the tasks runing in cRIO, therefor if the tdms read is runing in a highere priority task and using all the CPU, you will see a lost connection in the "Front Panel".
It is not a preferreded way to communicate with a cRIO. You should setup your own communication and make a local VI for the Host PC.
Remember that the cRIO also has a limitted RAM, therefor it will not be able to open all tdms files of any size.
Any data process of tdms files should be done on a Host PC.
10-26-2010 05:56 PM
Thanks dkfire, you are definitely right.
I changed my program to use separate FIFO to provide data to the data processing loop, and it works fine and much faster.
I will write a vi on the host PC to do the realtime system performance monitoring using network-published variable or TCP functions.
