02-29-2012 11:00 AM
I'm trying to use the express data storage VIs to read/write TDMS files but I get error -2588 on trying to open the file.
Here:
http://zone.ni.com/reference/en-XX/help/371361H-01
the error code is translated to "Failed to register the DataPlugin. The DataPlugin .uri file might contain invalid DataPlugin information.", but the message box that reports the error says "Labview cannot open the data storage file".
I've (re?)installed the plugin from the NI site but no success. I'm using Labview 2011.
Any ideas?
Solved! Go to Solution.
02-29-2012 05:04 PM
Hello Spruce,
Can you post an example tdms-file and VI to illustrate your issue?
This way we can try to reproduce the issue at our side?
03-01-2012 04:23 AM
It was the process of opening and creating the file that was failing.
The attached VI demonstrates the problem, although I have now discovered the reason for it. The 'Open Data Storage' VI insists on the .tdms extension being provided in the path whereas the "TDMS Open" VI appends the extension by itself.
I still think the description of the -2588 error code is unhelpful or the error code is being wrongly issued.
03-01-2012 10:26 AM
Hello Spruce,
Thanks for the feedback!
I'll make sure that it gets passed through the right channels!
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
