table control change display format
I have a table in my VI which display some information. however, the number of columes is too many(about 20) and the number of Row is only 5. So I want to change the display format:
original table
Name    Age       Sex......
Tian       30         female
Song      23         male
After changed:
Name      Tina        Song
Age           30           23
Sex           female     male
Another question. The information in colums is too much. some of them have 10 characters, is table control have any property to change the colume width to accommodation them automatically?
(2,692 Views)
Accepted by topic author song403
Transpose your 2-D array.
For column widths, there is a function called Get Text Rectangle.  Use that on each element of your 2-D array in the column of interest.  Use the maximum value, then set your column width to that.
(2,686 Views)
Where can I find the function you mentioned?
(2,671 Views)
On the array palette. Haven't you ever used quick drop or the search button that's on the functions palette?
(2,654 Views)
