tab control
Hi guys ,
I have a silly problem, I have a strict  data type tab control. where i have 3 tabs . I need to run the 3 different data acquistions like for example
first tab shows           Distance
second tab shows      Force
Third tab shows         Position of the motor
The problem is each sensors shd acquired data from their respective task and it is to be activated when i click the
tab1       distance shd be on
tab2       force shd be on
tab3      position to be
Can be get an indicator like a boolean variable when i see n click the tab and turn it off when i switch to next tab?
Boldness has genius, power and magic in it!'
(2,175 Views)
Accepted by topic author MaveenD
Are you using any Design Pattern Like - PC etc...
In an event structure you can set Tab Control Value Change
The New Value of the Tab Control will give you the Tab On which you are going
(2,171 Views)
