08-04-2011 02:53 PM
For some reason the System Exec.vi does not work any more. There are two errors that I get;
Code Interface Node: Labview subroutine link error
Code Interface Node: Object code is not loaded
When I right click over the Code Interface Node, and select Load Code Resource, it tries to look for CIN's (*.lsb). But I do not know just what and where to find what file I am supposed to load.
08-04-2011 02:58 PM
Something has changed on your system, if not the programming. Post your code so we can have a look.
08-04-2011 03:25 PM
There is no code, just the System Exect.vi itself
08-04-2011 03:31 PM
So how are you using it then? What commands are you giving it?
08-04-2011 04:38 PM
Who's been messing around in the LabVIEW directory? Did you or someone else overwrite System Exec? Perhaps with another version?
Try doing a repair of LabVIEW.
03-22-2016 11:12 AM
In my case the antivirus was blocking this VI, disable the antivirus and the problem was resolved
03-22-2016 12:27 PM
Don't forget to mark your own post as the solution since it was you who came up with the answer. This way, you'll be helping others. 🙂
03-22-2016 01:17 PM
Bill,
This was a response to a 5 year old thread and this user's very first post, so it isn't their message.
03-22-2016 02:07 PM
@RavensFan wrote:Bill,
Thanks - I didn't check to see if it was the OP that replied! (Probably the wording should have given it away also.)
But iis a solution - assuming the same error messages and whatnot... 😄
