Hello Every body
thanks for your help. i am using a sub vi for sine signal generation. as a vi it works fine. but when i called this subvi inside another VI it gives some problems. for example timer indicator works properly.it reinitializes as well in the sub vi, but in the main VI it does not work properly. means does not count the time.in the sub vi on the fly i can change the values of frequency and amplitude in real time, but when i use as sub vi, it does not reponse as i change the values in the control arrays.similarly pause and continue works properly in the sub vi, but once again in the main VI, it does not work properly.graph indicator also work properly in the sub vi. but here once again it does not work properly in the main VI.the pause resume indicator also does not blink, when it is continue. in the subvi it blinks very well.generally why the sub vi does not work properly inside the VI?i am sending my VI and sub vis.
any tips would be highly appreciated.
thanks
Regards
