03-07-2006 03:44 AM
03-08-2006 11:25 AM
I believe you mean your Waveform Chart is in Scope mode, not Strip mode, if you expect it to clear itself after filling the chart with data, then start over at the beginning.
You can make your graph less jumpy by turning off Y Autoscaling and instead setting the Y axis limits to something you wouldn't expect your acquisition levels to exceed.
If you have a VI which reproduces the intermittent behavior you are experiencing, please post it to the forum so that others can evaluate this behavior. Thanks!
03-08-2006 02:14 PM
03-09-2006 04:07 PM
