Hi Karthik,
You would need to do some calculations on the data going into the strip chart. Basically you want to add counts per second for 60 seconds which would give you counts per minute. You can put the data going into the strip chart into an array and later use index array and statistics express vi to sum every 60 elements of the array.
Ankita A.
